08 Nov 2023 01:04 PM
When I try to search for my recordings via the sky go app on my iPad, the iPad says it is unable to find any Sky Q box.
so points to note, yes I am connected to the same network as my sky Q box. My sky q box is switched on.
Sky go iPad settings does allow me to connect to networks.
Sky go app is up to date. But no matter what I try, my sky go app on my iPad just won't connect to my sky box. I can still watch some of the live channels, box sets and on demand. But not my recordings.
Any advice is greatly appreciated.
08 Nov 2023 01:15 PM
Posted by a Superuser, not a Sky employee. Find out moreDo you have a multiscreen subscription on your account, if you do have you tried a reboot of both your iPad and your Sky Q box ?
08 Nov 2023 02:36 PM
@caesarome Yes I have multi-screen.
i have also rebooted both IPad and sky q box.
I've even deleted the sky go app and reinstalled it. No joy
01 Dec 2023 06:11 AM
Hi, I was having the same problem but I remembered that I was using VPN. When I turned it off it solved it found the sky q box again.
01 Dec 2023 08:05 AM
@king+samoo thanks, yes I did turn off my vpn also.
I did install a new internet extender for when I'm upstairs. But it is a Tp Link one and is compatible with the tp li k router. So no different connection name or anything.
and even when downstairs next to the router it doesn't connect to sky q box ☹️
21 Mar 2024 11:11 PM
Hi, I'm having the same problem as Gillby, there was a recordings tab at the bottom right of the App screen.
When selected the iPad would search for the Q box but never find it!
After deleting and reinstalling Sky Go the recordings tab is not there anymore!
This is really annoying me now, please help?
22 Mar 2024 05:38 AM
On average, new discussions are replied to by our users within 3.6 hours
