Discussion topic: Does sky go use data if you have sky mobile
Message posted on 05 Mar 2023 12:48 PM
Message posted on 05 Mar 2023 01:03 PM
Re: Does sky go use data if you have sky mobile
If you are a Sky Mobile customer then apart from a really small amount when viewing some adverts Sky Mobile will not "charge" you any data when using Sky Go or any of the other Sky apps. Your device itself will show as data being used because it is but Sky isn't charging you for it.
Message posted on 14 Aug 2025 12:12 PM
Can i check is still the case now?
Message posted on 14 Aug 2025 12:21 PM
It is still the case as per the post above:
https://www.sky.com/help/articles/sky-mobile-watch
