8
This discussion topic has been answered Discussion topic: Can I watch sky tv on my sky mobile without using my data please ?
This message was authored by: Duncsamui
This message was authored by: best+of+the+best Answer
Re: Can I watch sky tv on my sky mobile without using my data please ?
@Mister_Dalek wrote:
@Duncsamui wrote:
I was thinking more of when I am away from home
Connect your phone to a WiFi network whilst you are away from home and you won't use any data.
@Mister_Dalek no mobile data will be used if @Duncsamui is using Sky Go whilst on the go until he can connect to a wifi connection
https://www.sky.com/help/articles/sky-mobile-watch#:~:text=Sky%20apps%2C%20like%20Sky%20Go,'Sky%20TV....
This message was authored by: Mister_Dalek
If you use WiFi then yes.
This message was authored by: martswain
If you have a SKY mobile contract then you can watch via the Sky Go and Sky Sports apps without eating into your data allowance.
Avatar for Duncsamui
Unless you are going somewhere with no wifi then @martswain reply is correct.
This message was authored by: Icarus
So if I watch on an iPad tethered by my Sky Mobile network on iPhone, use or without using my data? Thanks!
Correct, a really tiny amount will be used for some pre roll adverts otherwise your Sky mobile data will not be used as per this:
