Discussion topic: hi l cancer my sky tv cant get bbc1 and 2 itv and 4 and 5 pls help
This message was authored by: phil00
Re: hi l cancer my sky tv cant get bbc1 and 2 itv and 4 and 5 pls help
@phil00  if you have cancelled your tv subscriptions completely you need to disconnect from the internet and use the freeview tuner
Hi @phil00
If you have no subscription you will loose access to the TV guide. You will have to use each app (iplayer, ITVX etc) to view the streams.
See: https://www.sky.com/help/articles/sky-glass-without-a-subscription
Or as @SKY1992bf indicates if you disconnect from the internet you will be presented with an aerial option, allowing to to get some DTT (Freeview channels).
See: https://www.sky.com/help/articles/tv-input-app-on-sky-glass
Also you will have access to HDMI ports so can use external devices.
MikeAlanR
