Discussion topic: Where can I buy a bracket for my 55inch sky glass
Message posted on 22 Jun 2024 10:11 AM
So we didn't buy the tv bracket when purchasing our sky glass and now we want it. Where can we get one?
Message posted on 22 Jun 2024 10:45 AM
Re: Where can I buy a bracket for my 55inch sky glass
My wall mount was included with the stand which Sky supplied to me when I bought my Sky Glass TV recently. I don't recall having to ask them to include the stand when I ordered the TV. It just came with the TV in a separate box.
Did Sky not supply you with one of their stands when you bought your Sky Glass TV from them? If not then you would probably be best to contact Sky directly to see if they will supply one to you.
65" Sky Glass in Anthracite & 145 Mbps Ultrafast Broadband
Message posted on 22 Jun 2024 11:23 AM
@HarryH6 Is the TV on the supplied stand? If so then as pointed out by @MisterM18 you will already have the wall mount, it will be part of the stand.
Message posted on 22 Jun 2024 12:25 PM - last edited: 22 Jun 2024 12:26 PM
Message posted on 24 Mar 2025 03:17 PM
They charge extra for the mount. So if you didn't check the box and pay an extra 2 quid as part of the monthly bill, you only get the TV stand without a mount. I'm in the same boat as I thought I did check the box for the extra mount but evidently I didn't. So we can't mount the TV to a wall.
Message posted on 24 Mar 2025 03:25 PM
@DominicDSJ wrote:They charge extra for the mount. So if you didn't check the box and pay an extra 2 quid as part of the monthly bill, you only get the TV stand without a mount. I'm in the same boat as I thought I did check the box for the extra mount but evidently I didn't. So we can't mount the TV to a wall.
You can use a univeral VESA wall mount for the Gen 2 Sky Glass, just make sure the mount selected supports the weight of the Glass TV.
Message posted on 24 Mar 2025 03:29 PM
Yeah I just figured this from checking the forums. Thanks!
Message posted on 24 Mar 2025 05:34 PM - last edited: 24 Mar 2025 05:36 PM
That's changed between the v1 and v2 models. Answers above your post refer to the v1 (released in October 2021) rather than the v2 from February 2025.
Message posted on 22 Mar 2026 06:33 PM
The tv stand converts i. To wall bracket
Message posted on 22 Mar 2026 06:35 PM
@Claire01-1 wrote:The tv stand converts i. To wall bracket
Only on the gen1 Glass TV. Not on the Glass gen2 or Air.
