3
This discussion topic has been answered Discussion topic: What is the process to upgrade from sky glass TV to normal TV and keep sky streaming?
This message was authored by: graemeross
Hello, I want to upgrade my sky glass TV (that I own outright) to a larger normal TV But I want to keep sky services. Will they deactivate the TV and send me a pick? Or do I need to cancel and resubscribe to streaming only? Many thanks
This message was authored by: GD1 Answer
Re: What is the process to upgrade from sky glass TV to normal TV and keep sky streaming?
@graemeross  You would need to add a stream puck if you don't already have one, you will need to remove the Glass TV from your account by giving Sky a call, they will make the puck your primary device,you'll need to reset the TV to remove any persaanl details if you inetend selling it.
Avatar for graemeross
That's perfect thanks mate 👍🏼
Hi @graemeross  The advice from @GD1 is spot on but I wanted to add you are doing exactly what I did nearly 2 years ago and have never regretted the decision but I also purchased a low to mid range sounbar.  The puck quality on a decent OLED TV is just outstanding.
