9
This discussion topic has been answered Discussion topic: Wall Mount my Sky Glass air
This message was authored by: LisaH4
I bought a Sky Glass Air size 46 in July.  I have been really happy with it.  Now I want to put it up on the wall but Sky help have told me the only way to get a wall mount is to buy another tv.  Surely there is another solution???
Re: Wall Mount my Sky Glass air
@LisaH4
Glass and Glass Air use a slightly unusual 300x200 VESA pattern which not all mounts will have points for: typically 400x400 mounts can also accommodate the smaller spacings.
You can use any VESA compatible wall mount. They are available everywhere. You don't need the Sky Glass specific mount.
Avatar for LisaH4
There are holes on the back of the Sky Glass Air that didn't match the wall mount from B&Q
@LisaH4
Avatar for LisaH4
Thank you
This message was authored by: Janeoco1
Does this work for new GEN 2 tv's?
This message was authored by: Wellingtoncotta
Did you get sorted Lisa. Looking at a 43 inch glass air. However I don't want to purchase their £99 bracket. All worked out with a compatible
This message was authored by: vblockmatt
This is the issue im having. The centre ones 15cm apart dont appear to fit any brackets in find.
Unless 6 screws aren't needed?! Did you manage to find one at all?
I used this for my outside office/sportshub it worked perfectly
BONTEC No Stud TV Wall Bracket for 26-55 inch LED LCD OLED Plasma Flat/Curved TVs, No Drill TV mount with Max VESA 400x400mm, Plasterboard Studless TV Wall Mount, Bubble Level and Cable Ties Included https://amzn.eu/d/07gKIa9r
Thank you! It says it only uses 2 screws. Is that right?
If all 6 aren't needed and 2, or 4 are enough then I should be okay with what I bought.
Answered - Go to Answer
