16
This discussion topic has been answered Discussion topic: Voice control not won my sky glass, I have tried all the suggested help topics
This message was authored by: JBC11
The voice control is not working on my sky glass TV, I have tried all the suggestions already
This message was authored by: lettice Answer
Re: Voice control not won my sky glass, I have tried all the suggested help topics
This looks to be fixed now.
A number of you reporting all is ok with voice again.
Will mark this as Answer post.
This message was authored by: TimCh
Re: voice control
Voice control isn't working right now on any of my Sky Stream pucks (3 of them). Says "That didn't work please try again".  Sometimes the message appears before I even said anything. I've rebooted and factory reset the pucks. The remotes are connected and all other buttons are responsive.
any ideas ? Is this a sky side issue ?
This message was authored by: Rach851
Mine isn't either. Worked last night. I've rebooted it and now it hears what I say but doesn't see out the comman it just says "sorry that didn't work"
This message was authored by: Super+Anthony
Voice Control Sky Stream
Anyone having isses when using the Voice control on Sky stream controller? When I ask for something e.g. BBC1. It picks my request up but then doesnt change and says That didnt Work, please try again.
I havde done a restart on my Sky Stream as well
(Please Note: I am Neurodivergent )
This message was authored by: Bezza19781
Mine is not working either and I have tried all previously suggested fixes.
I actually thought it was broken so I'm kinda glad I'm not the only one.
This message was authored by: Deedee36
Re: Voice Control Sky Stream
@Super+Anthony  Yeah same issue here for me
“Trying to help improve sky glass”
Yes same here on both my Sky Pucks.
This message was authored by: Fellwalker46
Yes same here, getting same message when asking for something.
hi all, just had a useful call with Sky, and the helpful rep has said there is a known issue
Mine is back and working now.
Can you all check again and report if back and working too.
Yes all working now. Thank you.
Seems to be working again 🙂
Yes working now thanks
