Discussion topic: Took my sky glass to Spain, need help
This message was authored by: Omies
I've moved to Spain and need to change the region on my Sky Glass. Can anyone help please?
Re: Took my sky glass to Spain, need help
In short no, your Glass TV cannot work in another country as it is locked to Sky's UK service, essentually you won;t be able to use it in another country.  It would have been better to sell ir beofre you moved.
Did you cancel your TV subscription before you moved?
@Omies
Sky Group is not a licensed broadcaster in that country: they would be breaking national law by providing service on Stream or Glass there.
(And yes, I know about all the big dishes, but satellite signal is rather bad at recognising terrestrial borders ; )
@Omies
If you are trying to use the built-in digital terrestrial television tuner it isn't intended to be active in that country either: the list is of territories where Glass is officially distributed.  You'd need a locally-sourced external receiver or recorder connected over HDMI cable.
