3
This discussion topic has been answered Discussion topic: Tether phone to Sky glass
This message was authored by: RuthieDMB
I have no broadband and want to tether my sky glass to my phone. However,  there is no other network option apart from my non-working WiFi. How can I connect to my phone?
This message was authored by: Jporch316 Answer
Re: Tether phone to Sky glass
Are you saying that your wifi doesn't work or your phones wifi hotspot?
depending on your phone model you can turn on wifi hotspot on your phone and connect your sky glass to it
you may have to reset the network settings in settings n your glass to get it to find a new WiFi network
A cable.
Avatar for RuthieDMB
My usual Sky broadband is down. I have a working phone signal (iPhone 13) and have turned on the hotspot.
Thanks for your help. I have now been able to reset the network settings and find my phone in the list of available networks 😀
Answered - Go to Answer
