Discussion topic: Sky glass remote and add skipping
This message was authored by: JJR13
Hi, My Sky Glass remote went bang and stopped working. Also, ITVX ad skipping isn’t working even though it should be. Please sort both issues.
Re: Sky glass remote and add skipping
@JJR13 This is a community of other Sky customers so we can't sort your issues we can only offer advice.
For your remote control issue you need to follow the help flow in this guide (https://www.sky.com/help/articles/remote-control-help-sky-glass) , and if appropriate you will be prompted to complete a form to request a replacement remote. You may not be aware but there is also a mobile app that can be used as the remote control for Glass and Stream. https://helpforum.sky.com/t5/Sky-TV/Sky-Glass-and-Sky-Stream-Remote-App/ba-p/5150285
For the issues with the ads on ITV X, trying restarting the Glass as a reboot usually solves this issue.
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
