2
This discussion topic has been answered Discussion topic: Sky glass losing connection
This message was authored by: Si192
Hi can anybody help. I've had Sky Glass for a while and have recently changed to EE for my broadband. I've been having issues with both the sky Glass and the pucks. Every couple of days I'm losing WiFi connection to all sky devices ( no others though). I've tried rebooting the tvs, using Ethernet, resetting the tvs, changing settings, rebooting the router, changing the channels on the hub, only using 2.4, only using 5ghz, putting the devices into all modes. I've called Sky and EE more times than I should but both just blame each other. If anybody has a clue it would be appreciated!
This message was authored by: mikealanr Answer
Re: Sky glass losing connection
Hi @Si192
I had the same issue following a software update to the EE router in June. After making complaints with Sky and EE, sky provided evidence that my devices were failing to resolve over DNS.for short periods of time.
Following a further complaint to EE, I was upgraded from their smart hub plus to smart hub pro (which should have happened sooner as I'm on the 1.6Gbit package) and have had zero issues since.
MikeAlanR
Hi @Si192
MikeAlanR
Avatar for Si192
Hi MikeAlanR
Thanks for the info. It's been driving me insane for the last month or so. I've been going back and forth hopefully this will help me get somewhere
