Discussion topic: Sky glass loses internet connection overnight
This message was authored by: Popsy3
Hi,
can anybody help me with my sky glass tv issue.
i have it hard wired via Ethernet direct to the router.
firstly they told me sky live camera apps would freeze and the screen would just go black. You could only get it back by doing a 240v reset.
ive called Sky numerous times. Firstly they told me it was my Netgear router as I wasn't using theirs and had to pay for Wi-Fi Max. This didn't resolve it. They sent me a pod for some reason so I've connected it to that and hasn't resolved it.
so now I have WiFi Max router hard wired to pod hardwired to sky glass.
Now it also loses connection to the router overnight and won't reconnect even if you reset the connection in settings. As soon as you do a 240v reset it connects straight away. It does this every single night.
ive factory reset the tv and that hasn't resolved it.
Re: Sky glass loses internet connection overnight
Make sure you have the following settings set in your Sky Glass settings, if you do not at the moment;
Turn wifi OFF under Network if connected via ethernet.
Set Network standby mode to ON and Overnight power saving to OFF
Avatar for Popsy3
Thank you lettice
the only setting that is different is the overnight power saving. This is currently ON.
surely not good to turn this off as over long period will cost more?
@Popsy3 wrote:
Thank you lettice
I guess it's a balance of whether to spend a few pence more on power, or put up with the inconvenience of your broadband connection possibly dropping out.
@Popsy3 wrote:
Thank you lettice
It's probably worth a go turning it off and seeing if that solves the problem for you. If it does, you can weigh up the cost vs benefit but it's probably not worth worrying about until you know if that solves it or not.
Avatar for Popsy3
Thank you all for your replies.
I'll give it a go turning off overnight power saving feature
is this a common issue do you know?
Having to set overnight power saving to OFF and networked standby mode to ON is quite common to ensure that the network connection isn't lost when the device is in standby for a long period e.g overnight. What you are finding is that once the network connection shuts down it can ( and usually will) take a while for it to be re-established again when the TV is woken up.
In terms of additional power consumption, i really doubt it will be that much, you may only be looking at an extra couple of pence per day.
Avatar for Popsy3
Thank you.
The glass tv comes on with a blue screen stating No Internet and a Settings tab. I click on this setting tab and Reset internet but it just says No Router found. I can do this for 10mins. In the end I turn it off at the wall and back on again and it connects instantly once booted back up.
It never did this before the Sky Pod so was wondering why. As it is all still Ethernet from Tv back to Router
@Popsy3 wrote:
Thank you lettice
This does sound like the issue, that yes is a common issue on the community.
Especially as you mention recently changing connection via a Pod.
We have seen that those who use a managed switch rather than direct to router,  do need to turn off the option for it to come back cleanly. But, also often just those connecting via a mesh or even direct to router.
In the overnight power saving mode it does drop off the network connection after sometime and as you are seeing does not reinstate it promptly, other than a forced power reset.
We have found over the last few years of those with a Sky Glass. TVs and Sky Stream pucks that had similar issues and did  turn off the overnight power saving, had no further issues
As for a cost, it's going to be a few pence or even less a month of a saving to have the option ON.
Avatar for Popsy3
Thank you lettice
This message was authored by: R08YN
If you have a sky glass air there is no fix
Overnight Power Saving is hardcoded into the firmware and cannot be toggled off directly in setting like the other sky Glass
Because that specific power-saving feature is locked on, the system is forcing your device into a deep sleep state every single night. When you turn the device on in the morning, the Wi-Fi card fails to wake up or request an IP address from your router quickly enough, causing the "No Wi-Fi" bug.
You can wait and refresh, do a turn off and turn on, or change your router settings to your TV ip to be a 2.5ghz which does ip requests faster. [Yes the bug exists even with ethernet cable connection]
This message was authored by: WelshGeezer
Yes, this is a Sky Glass issue and only they can fix it. Our best option is to work around it by forcing the TV to use a static IP address, Ethernet and the home button to power it on. Sky appears unable to fix many ongoing bugs promptly.
Sky Glass 55" - Gen 2, Sky Glass 43" - Gen 2, Sky Glass 43" - Air (all on ethernet) & three Stream Pucks (all unused gathering dust in a drawer) powered by Vodafone Full Fibre - 910
Router? Two TP-Link Deco BE65’s (v2 / Firmware Version: 1.3.2)
