This discussion topic has been answered Discussion topic: Sky glass keeps freezing
Message posted on 06 May 2024 08:59 PM
My sky glass seems to keep freezing on the app it is saying that everything is working correctly. Is anyone else having issues with this.
Message posted on 06 May 2024 09:02 PM
This is all the signs of weak and unstable WiFi signal.
The sky streaming platform requires a strong stable and consistent WiFi connection to works due to it having to be permanently connected to Skys servers. This means any WiFi interference or dropped packets will likely cause the device to crash.
The solutions to this are typically to improve your WiFi signal, for example setting up a mesh network, of by using Ethernet instead of WiFi. When using Ethernet you need to disable the WiFi from the network settings and also give the device a reboot (unplug for 1 minute) to ensure the WiFi is disabled.
Message posted on 06 May 2024 09:00 PM
Re: Sky glass keeps freezing
@ACaswell How is your Glass connected to your router?
Message posted on 06 May 2024 09:01 PM
Its connected via wifi and all is working correctly.
Message posted on 04 Sep 2024 06:16 PM
My broadband is over 140mbps and 92% stable but it's still freezing if I go up a channel then back on it it's fine for a bit. Come on sky don't try and blame it on WiFi. Sort it sky your charge us enough.
Message posted on 04 Sep 2024 06:41 PM
@Scotch1979 wrote:My broadband is over 140mbps and 92% stable but it's still freezing if I go up a channel then back on it it's fine for a bit. Come on sky don't try and blame it on WiFi. Sort it sky your charge us enough.
Almost certainly a WiFi signal issue. Skys hardware doesn't use a buffer system that can hide WiFi blips. As suggested try an ethernet cable or cheap powerline adapters to connect your tv to the router. If the situation still persists you will know there's a separate issue. I originally ran my sky glass unit off WiFi on a 32mb connection but it was stable and fairly close to the router and didn't encounter any freezing. Sometimes it's not the speed that counts it's the consistency of signal receipt. Try running the network test in the native Netflix account and checking the actual speed your tv is getting
Message posted on 25 Sep 2024 02:02 PM
Did you actually read what I put? There is no interest problem. Sort out sky glass., I don't want a pre prepared statement.
Message posted on 25 Sep 2024 02:59 PM
Can you try it via Ethernet, if it works fine via Ethernet, then it's almost definitely a WiFi issue
Message posted on 25 Sep 2024 03:38 PM
My router is not near the the TV. But it's a 1 bedroom flat so not that far.
Message posted on 25 Sep 2024 04:32 PM
You can buy some extremely long Ethernet cables on Amazon
Message posted on 25 Sep 2024 05:53 PM
Well that answer is about as much use as a chocolate teapot. We pay enough sort your service out.
Message posted on 25 Sep 2024 08:57 PM
I'm a subscriber like you, I don't work for Sky
Message posted on 25 Sep 2024 08:59 PM
You're not talking to Sky customer services via the forum, this is mainly a customer helps customer community. This means other customers are helping you.
Message posted on 07 Nov 2024 12:08 AM
I can verify that my Glass TV freezes regularly too... and I am connected by ethernet. So it's DEFINITELY not wifi
Message posted on 07 Nov 2024 07:08 AM
@F1_fan wrote:I can verify that my Glass TV freezes regularly too... and I am connected by ethernet. So it's DEFINITELY not wifi
Run the network check in Netflix on glass and report back on speed
