Discussion topic: Sky glass and internet booster for garden building
Message posted on 28 Dec 2023 06:42 PM
Hi, hoping someone with more tech knowledge can help.
i currently have sky Q with 3 mini boxes, 2 in the upstairs rooms and 1 in an outbuilding that my daughter lives in, her mini box is a internet booster for her so she gets good internet signal out there too, my question is, I have ordered a sky glass TV, with 3 pucks, I have just realised she won't have the internet out there as she won't have the Q box, she is too far away from the house to pick up any signal, any ideas of a way around this please.
Message posted on 29 Dec 2023 07:29 AM
Re: Sky glass and internet booster for garden building
How was the Sky Q mini connected to the internet?
Message posted on 29 Dec 2023 09:49 AM
The mini is hard wired to the main Q box in the house, it then acts as a sky booster to offer WiFi out there, now I'm trying to work out how I can do this with sky glass, I will want to have a sky puck but also internet, I'm confusing myself more and more thinking how to do it, I may have to cancel sky glass if I can't get it to the garden room
Message posted on 29 Dec 2023 09:50 AM
Message posted on 29 Dec 2023 11:15 AM - last edited: 29 Dec 2023 11:36 AM
Get a network access point which can be connected to the Ethernet cable in the outbuilding and supply wifi pass through Ethernet to the Puck🙂
Message posted on 29 Dec 2023 11:43 AM
Or a mesh node or mesh WiFi system should do the same thing although you may have to do some setup .....
Message posted on 29 Dec 2023 11:49 AM
There doesn't seem any wifi connection from the main building in the outbuilding?
There is an Ethernet cable between the buildings😉
Message posted on 29 Dec 2023 12:03 PM
Most mesh nodes have an ethernet port for Ethernet backhaul
Message posted on 29 Dec 2023 03:47 PM
Yes this is correct there is no WiFi without the Q box and if I'm having glass obviously won't have the WiFi from Q box, can I run a Ethernet from the glass tv to the puck or to a WiFi booster instead of going from the router to a booster as the router is in a really awkward place
Message posted on 29 Dec 2023 03:57 PM
I would question your reasoning for switching from Q to Glass/Stream, especially if your current Q system works well.
Sky's streaming service is very different to Q, and whilst excellent for certain households, it can be incredible frustrating and limiting for others.
The pucks can be extremely temperamental without a fast and stable broadband connection and can suck up a lot of bandwidth if several are used at the same time.
You cannot connect an ethernet cable from a Glass TV to a puck, that's not how it works. Pucks require their own connection and cannot piggy-back off another puck or Glass TV.
I would strongly urge you to work out how and if you can supply a Glass TV and multiple pucks with a fast and stable enough network connection before purchasing, because without out it the Sky Streaming experience will be very poor.
Message posted on 29 Dec 2023 04:02 PM
I have the fastest fiber internet provided by sky so that shouldn't be an issue in the main house, it's just the outbuilding that I'm questioning, I didn't think of this when I ordered tbh so before I cancel it I was hoping for some kind os solution
Message posted on 29 Dec 2023 05:02 PM
Simplest solution to replicate what you have now is an ethernet switch on the end of the ethernet cable in the outbuilding, then a Stream puck and a Q booster (acquired second hand) on the switch. At the house end, the ethernet cable goes into the ISP router or another ethernet switch cabled to it.
Message posted on 29 Dec 2023 06:19 PM
The Ethernet switch needs to at the Sky Glass TV where the Ethernet cable that runs to the outbuilding originates?
A network access point is needed to replace the Sky Q mini in the outbuilding to supply wifi to the outbuilding🤔
An expensive mesh system is not required in the outbuilding😉
Message posted on 29 Dec 2023 07:21 PM
You can pick up a single google
mesh node used for £20 ....... if I'm reading right there is an existing ethernet cable running from the house to the outbuilding ?
Message posted on 29 Dec 2023 08:01 PM
While a new access point with Full Guarantee cost the same or less🤔
