Discussion topic: Sky Sports + keeps buffering and picture quality is very poor
Message posted on 17 Aug 2024 01:14 PM
Message posted on 17 Aug 2024 01:50 PM
Re: Sky Sports + keeps buffering and picture quality is very poor
Agree.
some feeds work fine. Others keep buffering, jump around and freeze. Hope it's just teething problems. Trying to watch Derby v Boro but unwatchable. Leeds and Pompey games are no problem.
sort it Sky
Message posted on 17 Aug 2024 02:06 PM
For my sins am watching Leyton Orient and it still bad. Peterborough game is the same.
Message posted on 17 Aug 2024 02:17 PM
Yes mine too!
Picture quality terrible and buffering every 5-10 minutes!
Message posted on 17 Aug 2024 02:40 PM
Same for me, multiple pauses every minute, very poor
Message posted on 17 Aug 2024 04:08 PM
Are you using wifi to connect to the tv ? Connection with an ethernet cable is more stable, also you need a min of 35mps tv the tv
Message posted on 17 Aug 2024 05:17 PM
Yes. Connected by Ethernet
Message posted on 18 Aug 2024 11:34 PM
Hi Moshkosh
i had exactly the same experience. Was trying to watch the Boro game but the constant buffering made it impossible, but the Baggies - Leeds game was fine. I hope Sky sort this - I'll complain and see what they say.
Message posted on 18 Aug 2024 11:39 PM
Hi sos meant Moshchop
Message posted on 07 Dec 2024 07:22 PM
Hi all I have FTTP so no issues with internet speed and F1 and live football do exactly the same as described above. Have some TV's over Ethernet, some over WiFi and one connected to a mesh hub and a Sky Glass - all the same issue. Another issue is Voice Sync, but I do have Sonos is some rooms. There is definitley an issue with live broadcast - feels like Sky are using a cloud server and trying to minimise costs if they are on AWS using EC2 you can select minimum processing power and therefore reduce running costs. Bit cheap really..........
Message posted on 29 Oct 2025 09:15 PM
Trying to watch a game now in the red button option and its awful, bad picture then goes black for long periods.
Message posted on 08 Nov 2025 03:11 PM
The quality of the sports channels just now is horrific across sky and TNT.
UHD is buggy. HD really inconsistent. Lines on football pitches jaggy, certain patterns or colours flash.
it's not my settings, they've remained the same for years. It's not my WiFi and I've turned it off at the wall several times.
