Discussion topic: Sky Glass not available Technical Fault
This message was authored by: GEnglish73
Good Evening,I have had issues with my broadband dropping out today which is now fixed. However when I switch my Sky Glass on this evening I am faced with this message.
I have tried turning it off at the plug to restart it but I am still left with this message. Help!!!!!!!
Re: Sky Glass not available Technical Fault
Try restarting your router as well and see if that helps
Avatar for GEnglish73
I tried restarting the broadband router and then waiting a while before switch the Sky Glass back on but I still get the same message. It is almost as though it fails to boot up the sky system. Could this be a software problem!
This message was authored by: Jporch316
@GEnglish73
 Try taking the plug out overnight or an extended period of time
