Discussion topic: Sky Glass freezing
Message posted on 06 May 2024 08:55 PM
Sky Glass freezing
Sky glass constantly freezing despite WiFi signal of 60mps or more
turning it off at the socket provides temporary relief but just be a software issue
We pay a lot for this - not good enough
Message posted on 06 May 2024 08:58 PM
Re: Sky Glass freezing
@roobarb9 Your not talking to Sky via the forum so you essentia;lly telling other customers it's not good enough.
Have you considered using ethernet to connect the TV to your router rather than wifi as wifi can be prone to signal issues.
Did you get the speed of your wifi from the netflix app speedtest? Or are you quoting your actual line speed?
Message posted on 06 May 2024 09:00 PM
Internet speed is only half the story. This is all the signs of weak and unstable WiFi signal.
The sky streaming platform requires a strong stable and consistent WiFi connection to works due to it having to be permanently connected to Skys servers. This means any WiFi interference or dropped packets will likely cause the device to crash.
The solutions to this are typically to improve your WiFi signal, for example setting up a mesh network, of by using Ethernet instead of WiFi. When using Ethernet you need to disable the WiFi from the network settings and also give the device a reboot (unplug for 1 minute) to ensure the WiFi is disabled.
Message posted on 06 May 2024 09:13 PM
Router is too far away for a Ethernet connection. We can watch tv in our iPhones without any problem in the sane room. The issue is Sky Glass software.
I know I'm not taking to Sky but they are not interested
An Ethernet connection isn't possible
no idea what mesh network is
Message posted on 06 May 2024 09:20 PM
@roobarb9 wrote:Router is too far away for a Ethernet connection. We can watch tv in our iPhones without any problem in the sane room. The issue is Sky Glass software.
Unfortunately just because streaming works on an iPhone doesn't mean your WiFi signal is strong and consistent. When streaming from say YouTube or Netflix for example on a mobile device, that's streaming directly from your device and will locally buffer and load the content. This means that in situations where your WiFi signal may momentarily weaken or drop out you don't notice. Unfortunately with the sky streaming platform doing little locally and it requiring a connection to Skys servers to stream anything network issues will cause it to act in this way.
Where Ethernet isn't practical as the router isn't close to the TV, power line adapters are usually a good alternative. This is exactly how I have my Sky stream setup after suffering from similar issues when I first tried via WiFi.
Message posted on 06 May 2024 09:29 PM
Given the money we pay, why should any of this be necessary? We abandoned the sky dish because any bad weather interfered with it
Doesnt help most channels have gone HD which is pointless
Message posted on 07 May 2024 12:02 AM
@roobarb9 wrote:Given the money we pay, why should any of this be necessary? We abandoned the sky dish because any bad weather interfered with it
A lot of ISP standard routers can be weaker with WiFi than some of the better models out there. That's where powerline adapters or mesh systems can be helpful. For the sake of troubleshooting can you move your sky stream box closer to the router temporarily and try an Ethernet cable or to see if the WiFi signal is more consistent ?
Message posted on 13 May 2024 11:48 AM
So all the answers in this forum are rubbish.
I have checked the WiFi signal with mine and my mothers.
they are both turning over a loading sign.
the signals are strong.
Never had the problem before and it's started on the same day.
I have 900mb broadband and my router is next to my tv.
my mother had a similar setup with slower internet but enough that the signal had never dropped before.
the problem is the interface and when people are paying a lot of money sky should be monitoring these forums.
Message posted on 13 May 2024 11:59 AM
@Lauralee678 wrote:So all the answers in this forum are rubbish.
How have you checked the WiFi signal?
To check what the Glass TV is actually receiving you need to run the network check from within the get help menu of the Netflix app. Not entirely intuitive, agreed, but in the absence of a proper network speed testing app, it's the only way to find out the network strength on the TV itself.
If your Glass TV is right next to your router you may be best connecting it with an ethernet cable and turning WiFi off on the TV's network settings. This can often help maintain a more stable connection.
Also worthwhile performing a full reboot of the TV - turn it off at the wall for a few minutes then power it back on.
Message posted on 13 May 2024 12:08 PM
thank you
however, we are paying a lot of money for this. This includes not having to plug a wire in. Otherwise, I wouldn't be using it. Obviously, I'm stuck in a contract now. So no way of getting out of it I assume.
i have checked wifi on the router and on other devices. I know it can differ. But it shouldn't be far off for a good quality tv.
But anyway, in the end we're paying for a service and we should be getting the service we are paying for.
Message posted on 13 May 2024 12:18 PM
@Lauralee678 wrote:thank you
I agree with you. That's why I got rid of Sky.
You can submit a formal complaint if you are not happy with the service:
https://www.sky.com/help/articles/how-to-make-a-complaint
Sky are generally quite good at trying to work with you to resolve service related issues.
Message posted on 13 May 2024 12:20 PM
@Lauralee678 If it helps I have read many posts on the forum from Stream/Glass subscribers who have successfully requested to return to Sky Q whilst still in contract. However your Glass TV will be a separate contract where you have bought the Glass TV and have a repayment agreement which will not be cancelled. You can however use Sky Q on the Glass TV.
Message posted on 13 May 2024 12:26 PM
Yeah,
problem is it's only my mum that has the tv.
I have sky stream and my own tv.
same thing happening on both though 🤷♂️
