Discussion topic: Sky Glass constantly freezing and out of sync
This message was authored by: Angela125
Sky Glass TV is constantly freezing and voices are out of sync.  Driving me mad as have to keep turning TV off and on, resetting the Hub.  It's not good.
Re: Sky Glass constantly freezing and out of sync
@Angela125 the buffeting sounds like the wifi signal from the hub to the Glass is notvstrong dnough. Run the Network test in the Get Help menu of the Netflix app. To watch in UHD thst needs to be greater than 25Mb/s ideally over 35Mb/s.Many people need more than a basic Sky hub to achieve those spedds and either buy https://www.sky.com/help/articles/sky-wifi-max or use their own third party wifi solution.
There is an issue with lip dyncsome customers are experiencing I find changing the channel briefly or going back to the home menu sorts it for me.
This message was authored by: Katrinajames
Same thing is happening to mine
This message was authored by: Jporch316
The out of sync is a current known issue (see large thread on this page)
if you are experiencing freezing then that would suggest network issues see @Chrisee post above to check speed
