Discussion topic: Sky Glass and PS5 settings
This message was authored by: Alex869
Hi can any one help????
When on the PS5 the screen blanks out for 5-10 seconds whilst playing! I know this is to do with the 60-120 Hz setting but I've tried everything! Please tell me what I'm doing wrong
This message was authored by: CoffeeDrinker
Re: Sky Glass and PS5 settings
There's not a great deal to set for PS5 on Glass. the set doesn't support 120Hz or VRR (variable refresh rate), the set is capable of 50Hz or 60Hz operation.  It will display 4K (3840x2160) at 60Hz with HDR on.
The set does support ALLM (auto low latency mode) , although experiences that have been posted here vary as to how well it actually works. Unless you play a lot of twitch based online multiplayer games, it might be best leaving ALLM off.
Sound wise you can pass 7.1 to the set, but it will only use the 3.1.2 speakers built in. Audio format wise use either Dolby Audio or Dolby Atmos. Not sure how well the set might cope with uncompressed 5,1 or 7.1 PCM.
Sky Glass & Stream Puck customer w/Sky Ultimate & Netflix, Sky Cinema, Whole Home & UHD/Dolby Atmos add-on.
