This discussion topic is read only Discussion topic: Sky Glass & Sky Stream Playlist issues 01/02/2024
Locked
This message was authored by: TheWarings
My Playlist history has disappeared
All the previously added programmes in my playlist have disappeared. It's only giving option to Manage All or Sky Store Purchases
Avatar for GD1
Level 16 icon
Re: Continue watching rail
@Ian283  I have merged your post to this existing thread that is discussing the same issue, the thread you used was an older thread where this is a new issue today.
This message was authored by: Linsey1
Re: Sky Glass & Sky Stream Playlist issues 01/02/2024
I've just found everything via the manage all button. But still really frustrating!!
@GD1 If you can't do it yourself might be worth asking a CM to lock the older thread to save any confusion
This message was authored by: Lucie101282
Programs disappeared from sky glass playlist
Programs on my sky glass playlist have disappeared
This message was authored by: James3261
I've called Sky and said they do a system update. Made no difference! Useless.
This message was authored by: KirstyLO
Vanishing playlist
Twice our playlists have disappeared off the sky glass TV. Can I retrieve them or prevent it happening? Can't remember all the things on there to re add everything?
Avatar for GD1
Level 16 icon
@SKY1992bf  Don't really think it's an isse as no one is adding to the thread.
Re: Programs disappeared from sky glass playlist
@Lucie101282 @TheWarings
Your posts have been merged into this joint Glass/Stream thread on this issue. Sky are aware of the problem.
@GD1  Fair enough, might be something to keep in mind if you see a sudden major influx on that thread
For anyone recently joining this thread who missed my earlier post.
A little work around for the issue. If you go to the manage all button on the playlist it still lists the shows (as a list in alphabetical order) you can use that in the interim whilst Sky fix the issue.
The tracking of what episodes you have watched it also still working on each individual show based on my testing.
This message was authored by: Abbi93
Layout change on playlist
i just went onto my play list and I can no longer see a photo with each program title. It now states manage all and I have to click on this and then see all of the program names in a list but no cover photo. I really don't like this new layout! Can I change it back to how it was before?
This message was authored by: Anders73
Re: Layout change on playlist
Hi @Abbi93 it seems it's a larger issue that's being investigated by Sky. Hopefully will be resolved soon.
Sky stream #1 - Sony OLED & soundbar
Sky stream #2 - Sony OLED
This message was authored by: Happyglass9
Playlist selections on Glass have disappeared
I wanted to watch something from a playlist, but none of the programmes I had added over past weeks, were on the playlist, with a message stating "you haven't added anything to your playlist yet"
I have 5 separate playlists for different family members & subjects, strangely an odd few programmes were there but these were ones I had tried to remove a little while ago, but was unable to do so because the "remove" button was not available.
I tried a reboot to see if the playlists would be restored but they weren't.
The TV guide showed that programmes should be on the playlists but the playlists didn't agree.
I experimented by removing a programme from the TV Guide list & then adding it again, but it didn't appear on the playlist when I went in to check.
Has anyone else had this problem? If so, is there a solution or do I have reinstate the programmes from scratch.  Any advice will be welcomed.
This message was authored by: angeleyes37
Least I know my kids didn't just delete my lists hopefully will be fixed soon 🤞🙏
Locked
