This discussion topic is read only Discussion topic: Sky Glass & Sky Stream Playlist issues 01/02/2024
Locked
This message was authored by: Wobdot
Re: Sky Glass & Sky Stream Playlist issues 01/02/2024
My playlist has gone, I'm happy in one way as I had programs which I couldn't delete
This message was authored by: Nikkynaks
My playlist is back!!!!! 😁
This message was authored by: Anders73
Mine is alive too!
Sky stream #1 - Sony OLED & soundbar
Sky stream #2 - Sony OLED
This message was authored by: Jimjob
Sky Glass Playlist Not Working
My Sky Glass Playlist has disappeared, along with my wife's and another playlist. When I try and add a programme to my playlist it confirms its done it, but it doesn't show on my playlist. I've tried turning the TV off at the mains, but so far no luck. Very frustrating - any help please
Re: Sky Glass Playlist Not Working
@Jimjob
Your post has been merged into this joint Glass/Stream thread on this issue. Sky are aware of the problem. Some customers are stating it's working again for them.,
@Wobdot  This is just a glitch which will be resolved soon.  When the Playlist returns it will come back with all the programmes that were originally on it.   I have never had a problem with removing things from my playlist.  If they don't delete in the usual way then go to Manage All and delete from there.
If you are meaning you can't delete from the Continue Watching rail then that is a completely different and frustrating experience.
This message was authored by: Elf
Playlist is empty,
Our playlists have emptied, even new programmes added over the last couple of days. They are showing in the manage section,  but are not available to watch. They were all in the playlists yesterday. Any suggestions other than adding them all again?
This message was authored by: WillboBaggins
Re: Sky Stream Continue Watching
Thank you
This message was authored by: PSC133
My playlist and continue watching rails have now returned.
Avatar for GD1
Level 16 icon
All
Customers should start to see their playlists returning, if yours hasn't you don't need to take any action, please be patient and it will return on it's own.
This message was authored by: Loue
Mine now all working - clearly sky issue
This message was authored by: Home+75
If you go into settings then click on update apps it resolves the issue.
@Fothergill1 thank you! I've had a programme I've not been able to remove in a playlist for months! I never knew you could remove stubborn ones using "manage all"
This message was authored by: Lin+B
My playlist now restored.
This message was authored by: GingerLC55
Yeh all back 👍😃
Locked
