4306
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
Re: Sky glass tv won’t turn on red light just keeps flashing
Check the Sky Service Checker through My Sky, that will tell you when Sky no longer an issue.
This message was authored by: Mumabear3
Re: Sky glass won’t turn on
Mine hasn't turned on all day! It's driving me nuts! I've tried everything, it comes on and starts an update then turns off again. I tried calling sky and there's a messaging saying there are technical faults causing issues for sky glass customers and they have the right teams working on it. But nothing has changed all day so god knows how long we will be without tv!
This message was authored by: Stephen+Mourton
Re: Sky stream not working
@Claire22915  Firstly have you tried unplugging the puck, leaving it for a couple of minutes then plugging it back in?  The old turn it off and turn it on again trick often works.
if you have tried that when the word 'Sky' appears does it say anything else even if you leave it for a few minutes?
This message was authored by: Hobbayne64
Re: Sky Glass Power up Issues 19-9-24
What a bummer, I cant even play my playstation.
This message was authored by: Dave1379
Re: Brand new sky puck, plugged it in and it flashes white for a few seconds and then turns off.
There appears to be an issue nationally. Some information on the Sky Glass forums. I'm in the queue for an on-line chat...
There is a known service issue. If you check the Service Checker via My Sky you will see Sky are reporting an issue affecting the Streaming TV service.
@Pronghorn1
I've merged your post into this thread on the Glass board as it's definitely not a Sky Q issue where you posted.
Re: Stream puck won't turn on
Best way to track the progress will be to occassionally check the Service Checker via My Sky as you will see Sky are reporting an issue affecting the Streaming TV service.
This message was authored by: Mel110
Sky puck flashes white and tv won’t come on
Sky puck flashing white tv won't come on
All you can do is occassional recheck the service checker for any updates.
Avatar for GD1
Level 16 icon
This also affecting Sky Glass also https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/td-p/4755170
This message was authored by: Wardy2
Same here. I have tried everything and followed all of the guides, but the stream box won't turn on. Very frustrating!!! What are we paying for?
This message was authored by: Stephmac35
Sky streaming puck keeps flashing white
Sky streaming puck keeps flashing white and not turning on .
This message was authored by: masoniscute
Tv wont turn on
My sky glass won't turn on I've done everything! Turn tv off press button on side of tv it comes on says its updating the software then go's again
This message was authored by: Natalie901
Yes I'm having same issues too with mine tried all the restarting stuff and no luck! Hope they sort it out soon!!
Locked
Answered - Go to Answer
