13
This discussion topic has been answered Discussion topic: Sky Glass 65" tv wall mount help
This message was authored by: John124
I have received my sky glass 65 inch TV and want to mount it to the wall I will use the bracket that came with the TV can anyone show me a picture of how they put the bracket on the wall. Thanks
This message was authored by: Fothergill1 Answer
Re: Sky Glass 65" tv wall mount help
Hi @John124 I have provided a link below to the Sky Glass wall mounting guide which should hopefully give you all the information you require.
YouTube also has a number of videos on the subject.
@John124
(Not my picture: from another forum poster)
This message was authored by: DarrenMiles
If you use the black spacers supplied with the Sky Glass TV it WILL NOT sit flat against the wall, but protrude by around 16mm or so.
This will allow you to be able to accommodate the protrusion of a 3-pin plug for the power lead between the back of the TV and the wall. However, if the purpose of this design is to allow the back of the TV to sit flush to the wall, the spacers have to be omitted.
in order to get the back of the TV to sit flush to the wall using the mounting plate supplied with the TV, which also is used for the stand, I found that I had to use at least a thick (penny type) washer or 2 at each top fixing hole, between the back of the bracket and the wall, plus a single washer at each bottom fixing hole, in order for the TVand wall mount bracket to correctly engage into one another, thus allowing the TV sit flush to the wall.
This is definitely a 2-man job, but can be extremely fiddly to get alignment of the TV and bracket perfect.
The alignment template supplied with the TV will help, however if this is taped to the wall it may prove difficult to remove again once you get the bracket correctly engaged into the back of the TV.
Are there any Sky engineers/fitters who can confirm the correct wall mounting procedure in order to get TV sitting flat against a wall, as the template and fitting procedure shown on the wall mounting instructions  supplied with the Sky Glass TV appears to be incorrect, especially as they show that the black spacers should be fitted between the back of the wall bracket and the TV, meaning it WILL NOT sit flush to the wall.
Sky does not have 'engineers/fitters' for Glass.  I suspect a perfectly flush fit was never a design ambition, particularly as that significantly increases the risk that the top lugs won't be safely engaged.
This message was authored by: Carol120
I have a 65 inch what steel coach srews i need
This message was authored by: Mister_Dalek
Depends on the type of wall you're attaching the TV to.
Brickwall
@Carol120
It's not possible to safely advise on fixings through a forum.
Remember that the most likely point of failure is the wall fabric itself, not the bolts.
This message was authored by: QUEENBEE1
Did you have to buy this
This message was authored by: Paige12345
Does anyone know if you can buy the TV wall mount bracket from anywhere or if there are any other brackets that will be compatible with the sky glass tv?
@Paige12345 VESA wall mounts are compatible. Just make sure it and the wall fittings can take the weight of the TV.
Thanks so much!
This message was authored by: Martin284
This picture ,assuming its a sky mount is not correct, the wall mount should be screwed flat to the wall and the black 'spacers' are screwed into the back  of the TV. These 'spacers ' are used to hang the TV onto the wall mount and the TV is secured with 2 bolts supplied with the mount. This leaves the TV flat to the wall and the mount is adjustable.
Answered - Go to Answer
