Discussion topic: Removing Sky Glass Air Stand
Message posted on 25 Aug 2025 05:59 PM
The sky glass air stand is not very sturdy so we've got a separate more heavy duty stand to display it. One of the pegs on the stock stand however seem to be a bit stuck - is there a way of safely removing it without applying a lot of force and potentially breaking the TV?
Message posted on 26 Aug 2025 02:37 PM
Re: Removing Sky Glass Air Stand
@Lank wrote:The sky glass air stand is not very sturdy so we've got a separate more heavy duty stand to display it. One of the pegs on the stock stand however seem to be a bit stuck - is there a way of safely removing it without applying a lot of force and potentially breaking the TV?
No. Afraid not. You'll need to carefully use force and hope it doesn't break the plastic.
