5
This discussion topic has been answered Discussion topic: No option to book fury usyk on sky glass... help please
This message was authored by: lukybenji13
I cant see how to book fury usyk fight through skyglass. Has anyone managed to book it on glass?
Re: No option to book fury usyk on sky glass... help please
@lukybenji13 its on my set up but its a bit hidden go into Sports on the supersection rail, scroll down to the rail of sports go right to boxing then it is the first tile it may get more prominent nearer next Saturday.
@lukybenji13
This page says
2. Sky Glass & Sky Stream (From Friday May 10)
  1. Press Home on your Sky remote.
  2. Select the event from the menu.
  3. Enter your Sky TV PIN, if enabled or select Purchase.
You'll be charged for the event when you enter your PIN (if enabled), and the order is confirmed.
If you change your mind about the event, you'll need to call us before the event starts. There may be a delay of 40 seconds or more behind the live event.
Avatar for lukybenji13
Hi, yes I have followed the instructions but there is no fury usyk fight anywhere on my glass to order... I am confused... I cant work it out and it's really frustrating. Thanks
Thank you
I suppose technically 'select the event from the menu' does cover that ; )
