Discussion topic: My5 won’t load on on my Sky Glass
This message was authored by: MartinV
Re: My5 won’t load on on my Sky Glass
Regarding previous message: it is like when you go off the app in the first place it is not actually closing down correctly which then leads to problems reloading the app unless you restart device which forces the app to close down.
My Set up:
Sky Glass Gen 1 + Sky Ultimate TV + Sky Sports + Sky Cinema + Ad Skipping
This message was authored by: Harves
Hi @MartinV
Mine is Sky Stream.
Yes this is correct! I had logged in on Channel 5 app & was watching a few episodes of a series. After I had left for a while & tried to reconnect, it just tries to load, but nothing happens.
My 5 & 5 were merging together at the time. So I'm not sure if this affected it!
So therefore I came to the conclusion also that the app can't seem to close down correctly.
I received a message from Sky which told me to re-boot everything & then re-sign in to all apps.
I followed this & nothing happened at all. Sky said they had hoped that would solve the issue. As it didn't they stated they knew there was an issue, But they couldn't help any further in regards to it.
I hoped they could of done something on there end. But this isn't possible..
So if anyone finds an issue, I'm waiting ☺️
This message was authored by: M.D.G.
In the end I had to factory reset my sky glass and reset it up.  This fixed the problem.  It is a little onerous as you have to relog into apps such as Netflix and Amazon Prime but you can quickly reconstruct your watch list as it seems to retain them after the reset.
This message was authored by: Itchiebott
I did a factory reset begrudgingly and. It worked for now
Thanks @M.D.G. & @Itchiebott
I'll try another go at this & see if it adjusts it!
This message was authored by: Ani31
Hi
I also did a factory reset this morning and so far seems to be working. Thanks for the advice all
This message was authored by: Mrsljp
I've been having problems since Jan 5 app won't open will sometimes let me watch 1 episode of a series then I have to keep refreshing the app it's getting beyond a joke
This message was authored by: amandag71
I am having issues I've tryed reset, I see yours was in January have you resolved this issue or did it just work by itself,
or still not working  ?
many thanks
Same issues here
For those who missed my earlier comment, I did a factory reset.  That resolved the problem, but has the incovience of having to relog into apps such as Netflix.  The watch list seem to reconstruct itself.  I haven't had any problems since then.
@amandag71
I've done a factory re-set & unfortunately this hasn't resolved my issue with 5 App. So I'll have to re-try again!
@Mrsljp
How have you been able to re-fresh the 5 App?? I've done it through the settings. But this has done nothing. So just wondered if I was missing anything??
Thanks x
@Harves It can take up to 24 hours for the refresh apps to process.
This message was authored by: swr1
Re: Chanel 5 straight to error
I've never been able.to stream anything on my pick from channel 5 (or it's various incarnations) since switching from a dish to the puck.  I've restarted rebooted factory reset and all other things suggested by the Sky chat bot (let's face it, it's AI, not a human with actual problem solving abilities!) but no joy.   Gutted as I love All Creatures!   Do I get a rebate/ my account credited if I have to buy my fave programs.from an alt platform - I suspect not.
Come on sky, this has been an issue for yonks... Do we need to get breakfast telly and or Martin Lewis on the case?
This message was authored by: Est6
My5 is a black screen on my Sky glass after I have refreshed apps
This message was authored by: DarrenB7
Worth checking router settings for ad blocking, as that causes me issues with the 5 app when trying to load programs.
