Discussion topic: My sky glass tv remote stopped working
This message was authored by: Adegboyega
My sky glass tv remote has stopped working and the buttons are malfunctioning. Can I request for another one?
Re: My sky glass tv remote stopped working
@Adegboyega some things to try:
Reset the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel. It
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
