Discussion topic: My sky glass is saying there is a technical issue
This message was authored by: Francesca00
Ive turned my sky glass tv on and it says, Sorry, because of a technical issue, youre currently experiencing a limited service. Please be assured that were working hard
to fix the problem.
Re: My sky glass is saying there is a technical issue
@Francesca00
I'll move your post from the Sky Q board.
@Francesca00  Have you checked your netowk settings in the Glass settings menu?
Go to settings --> Standby and startup --> Networked standby mode = set to on.
Check Overnight Power saving is set to off.
This message was authored by: Jporch316
@Francesca00
Might be worth pulling the plug from the wall for 5 minutes .....
