Discussion topic: Lights flash but then goes off
This message was authored by: Wendy143
Message posted on 19 Dec 2025 08:01 AM
When I turn on the lights flash but then the box goes off
this happens a lot and is getting more regular
Find out more
Message posted on 19 Dec 2025 10:55 AM
Re: Lights flash but then goes off
Hi @Wendy143
You have posted in the Sky Glass board which is Sky's TV set. Sky stream has one light on the front. If your box has more than one light it's likely Q or +.
Please can you clarify so we can get your post moved to the correct board and those with the relevant knowledge will be able to assist.
MikeAlanR
