Discussion topic: Keeps cutting out when a go to recording
Message posted on 06 Apr 2024 10:42 PM
That TV keeps cutting off when a go to recording
Message posted on 07 Apr 2024 04:33 AM
Dose anyone skyclass cut out or the remote stop working
Can anyone help dose ur sky class cut off or ur remote stop working ur having to turn the TV off then back on
Message posted on 07 Apr 2024 06:59 AM
Re: Dose anyone skyclass cut out or the remote stop working
I think you're stating you have Sky Glass so I'll move your post to the appropriate board.
Message posted on 07 Apr 2024 01:25 PM
Yes mine does the same
Message posted on 07 Apr 2024 01:30 PM
