110
This discussion topic is read only This discussion topic has been answered Discussion topic: Glass/Stream: There is a technical fault, please try again later/latency when changing channels
Locked
This message was authored by: HH2411
Re: Technical fault
Hi I'm getting technical issues too all morning! Netflix and other streaming platforms are ok, it's just sky that the problem. Anyone any news about it?
This message was authored by: Brodcael
Re: Glass/Stream: There is a technical fault, please try again later/latency when changing channels
Same issue in Bolton, tried rebooting both router and puck and now screen is frozen
I and many others have had this issue this morning but it has now been fixed.   You may need to reboot your Glass TV or Puck.  After I did the reboot 30 minutes ago I have not had any more trouble.
This message was authored by: Nigel19076
  • Yes i fixed it, i noticed it said " Software updating" in settings.
Tim
This message was authored by: Tracey177
Technical fault
Tv won't load
This message was authored by: Alan791
Frustrated subscriber says on my sky app that all the service are good they are not no pictures on t
What a load of **bleep** my sky app say all your services are good they are no picture on my sky glass just a lovely colour blue this happens a lot so bloody frustrating
This message was authored by: Shirley73
Technical fault
Could get ITV1 this morning, now nothing. All light at green on modem etc. Message on TV says technical fault, try later
This message was authored by: Nikki1701
Technical fault - Sky stream
Not been able to use my sky stream all day, every channel I try to play comes up with technical fault. Internet connection is fine as I'm able to stream perfectly on other platforms
Re: Technical fault - Sky stream
Have you fully rebooted your puck? Turn it off at the wall for a minute or two then power it back on and allow it to restart.
Sky claim that a reboot will solve the issue which caused this to happen to many customers this morning.
This message was authored by: dj801
No picture again
Technical fault,please try again later
nearly every day now
what's going on
This message was authored by: ShazR
Technical fault all channels
Cannot get any channels due to technical fault
This message was authored by: Welshy88
Glass is not working
I've checked all connections and my glass is not playing any channels
This message was authored by: TVNotWorking2
Technical Fault on Sky Glass
Had blue screen and technical fault message all day but your service checker says everything is fine. Very frustrating
This message was authored by: Suey1309
My to channels are off and showing technically issue
My sky glass will not load a channel it says there is a technical fault please try later
Re: My to channels are off and showing technically issue
@Suey1309
There was an issue with Stream / Glass this morning which was fixed. Try rebooting the puck.
Locked
Answered - Go to Answer
