110
This discussion topic is read only This discussion topic has been answered Discussion topic: Glass/Stream: There is a technical fault, please try again later/latency when changing channels
Locked
This message was authored by: Addicted
Re: Technical fault
I'm getting the same message. It has happened 3 times now since around 7 am.
This message was authored by: Kp9624
Re: I am getting the following message on my tv. There is a technical fault. Please try again later
I am getting the exact same issue. On all Sky devices
This message was authored by: KevNewMedia Answer
Re: Glass/Stream: There is a technical fault, please try again later/latency when changing channels
Posted by a Sky employee
Hi Everyone
Thank you for your patience. Our support teams have advised that the problem has now been resolved.
If you are still having problems, can you restart your Glass TV or Stream Puck. We appreciate that you've used the Community to help resolve the problem and hope that you continue to use this service!
Kev
Community Manager
This message was authored by: Murf65
Tec issues
Constantly onscreen showing technical issues, unable to get any channels, reset 5 times and still nothing
This message was authored by: Oriel__
Re: Technical fault
I keep getting tec Fault on BBC1 'try later'
This message was authored by: Graham200
Re: Technical fault
Same here  suffolk    Sky Glass. Rebooting TV and internet router hasnt helped
This message was authored by: Duds2
Re: Technical fault
Same here - am in NW Kent area
i had full fibre cable installed yesterday- wonder if they wired it wrong lol
This message was authored by: Alexbowers
Keep being home screened
While on a channel it says please wait for program to load then home screens me
This message was authored by: Garyt71
Sky glass technical fault
All im getting tiday is no network when there definately is.
And technical fault on every channel.
This message was authored by: Zxanadu12
Re: Technical fault
I am in the Derby area and getting the same issues
This message was authored by: mickyboy21
Re: Technical fault
Can't watch cinema this morning even though I have ot on my package
This message was authored by: Cas011
Re: Technical fault
Same here in Suffolk, it's a shame Sky continues to report there are no technical issues and everything is working 😡
This message was authored by: yiayia
Re: Technical fault
I'm in London and have had the same issues. Have rebooted ok for a little while then technical error message.
This message was authored by: Maggie84
Re: Technical fault
Me too. I'm in Dublin South Ireland.
Only thing I can watch here is Netflix Which comes free with Sky stream. Everything else is 'Technical fault'. Happening since 7am 9/12/25.
This message was authored by: TonyJoll
Getting exactly the same issue - all morning!
Have rebooted Router and Boxes - after a few minutes, getting same error when channels changed OR box refusing to change channel.
Come on Sky, your service is getting worse!
Locked
Answered - Go to Answer
