17
This discussion topic has been answered Discussion topic: Glass: I'm connected via Ethernet and on first power up, it tells me I don't have a connection
This message was authored by: ShellC
Re: Glass: I'm connected via Ethernet and on first power up, it tells me I don't have a connection
I'm having the same issue...none of the fixes or workarounds are helping 😕
Re: Sky puck technical fault
@ShellC
As mentioned above.
Sky are working on the issue and looking to fix.
In the meantime, try the temporary fix in the answered post.
Hi @Rohad I Note you are connected via Ethernet. There is currently a known issue when connected by Ethernet which Sky are working to resolve.  Have a look at post 12 above and you will see it contains a workaround which saves you having to reboot when the error message occurs.
You could also try using WiFi instead of Ethernet to see if there is any improvement.  If you decide to try this make sure you turn WiFi back on in the Network Settings (as you are using Ethernet it should currently be turned off).
Here are a couple of other links that might also help
https://www.sky.com/help/articles/sky-glass-no-internet-connection-osm
https://www.sky.com/help/articles/connect-devices-to-broadband-start
Answered - Go to Answer
