23
This discussion topic has been answered Discussion topic: Gen 2 best picture settings - not impressed
This message was authored by: Steve93
Just recieved my Gen 2, 55" not impressed with the picture so far,   really washed out, especially bbc news, everything looks really dull, can't seem to get it right, I've got backlight off,   can anyone give any pointers please?
Re: Gen 2 best picture settings - not impressed
@Steve93
The suggestion on the Gen 1 Glass was to have 'auto backlight adjustment' switched off: note that this is not the same as 'local dimming'.
Turn the backlight on. Much brighter with it on. Then play around with the backlight setting and the advanced settings to get the colour how you want it.
This is mine with backlight on;
Avatar for Steve93
Level 5 icon
Thanks will do
@Steve93
Avatar for Steve93
Level 5 icon
Well had a play about with the picture settings on my Gen2, got to say I'm impressed, looks good now, also it seems alot quicker at loading apps than the puck, I will be keeping it, superb
This message was authored by: PaulB1969
Can't help with the Gen2 but you could try the settings from this thread , made a massive difference for my Gen1
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-calibrated-MEASURED-settings/m-p/4626785
Sky Glass (S-43") , 3 pucks, Sky Broadband Ultrafast (FTTP) 1 Gbps , 3 Sky Max Pods
Avatar for Steve93
Level 5 icon
I'll try it
can you post your pic settings when you have ones you are happy with for now sport seems best for sound or auto.
Avatar for Steve93
Level 5 icon
Tried the settings on the Gen2, didn't like what it made the picture look like, reverted to my previous settings, these are the photos, still not quite right they look as though they've got too much red in them, a bit more playing me thinksIMG_3594.jpegIMG_3596.jpegIMG_3597.jpeg
No worries , I played around for ages before I discovered those Gen1 settings , wonder if the original poster of those will get a Gen2
This message was authored by: Hunter2660
Try reducing the red a little and increasing the green slightly . I did that on my Gen 1 and the picture appeared a little more balanced (at least to my eyes it was more pleasing).
Avatar for Steve93
Level 5 icon
Do you think my picture look red?
Avatar for Steve93
Level 5 icon
These are on the Extra-vivid  settings, too much colour I think IMG_3604.jpegIMG_3603.jpeg
I'm not a fan of the Extra Vivid mode, some like it, but I think it's too garish. It's what pleases you though. I suggested turning back the red a little because you mentioned it. I did it on my Gen 1 and turned up the green a tad, that suited me, but it won't please everybody. Just tinker until you find a picture that pleases you.
Avatar for Steve93
Level 5 icon
