2
This discussion topic has been answered Discussion topic: EXTERNAL HDMI connections disappeared with latest firmware on Sky Glass
This message was authored by: Miklos
Who else experienced this?
You can no longer selext external sources (HDMI 1-3) - only APPS! 😞
DEFINITELY NOT HAPPY!!! 😡
55" Sky Glass Anthracite (Ethernet) • Sky Live (VC100-ant) • Whole Home pack with 1 SKY Stream Puck (WiFi)
512Mbit FTTP Internet (Fibrenest)
This message was authored by: mikealanr Answer
Re: EXTERNAL HDMI connections disappeared with latest firmware on Sky Glass
Hi @Miklos
No all working here. Have your tried powering off at the mains for 5mins and seeing if they reappear? Also if they are missing from the apps and inputs rail, are they showing in the actual apps and inputs screen?
Also what happens if you try to switch inputs via voice commands?
MikeAlanR
Hi @Miklos
MikeAlanR
Avatar for Miklos
Level 4 icon
Thanks, @mikealanr !
Yep, the full power cucle sorted the issue... I have now again Ext sources...
Well, I did not know that the Glass OS has got a likeliness to Windows! 😄
