10
This discussion topic has been answered Discussion topic: Does a Sky Glass TV Hardware model "LT165-01-SKY-wht" stand for Sky Glass TV Gen 1 or Gen2?
This message was authored by: Pred
This message was authored by: Jporch316 Answer
Re: Does a Sky Glass TV Hardware model "LT165-01-SKY-wht" stand for Sky Glass TV Gen 1 or
The gen 2 s speaker fascia's are  colour matched to the tv
the gen 1 s speaker fascia's were black
Hi @Pred
@info from February was the following were gen2 model nummbers ..... unfortunately I don't know if the list has been updated since
LT143BLK, LT143BLU, LT143WHT
LT155BLK, LT155BLU, LT155WHT
LT165BLK, LT165BLU, LT165WHT
@Pred
My gen 2 blue 55 inch has the following model no
LT155-01-SKY-blu
Avatar for Pred
Screenshot_20250409_222303_Gallery.jpgthe picture attached is my Sky Glass TV Gen2 TVs  "Arctic Silver" and hardware model is "LT165-01-SKY-wht" and I thought that WHT stands for White which is being sold aka built as Gen1 and hence i was wondering do i have a genuine Gen2 or using it Gen1. Your list posted shows that WHT is mapped to Gen2 - right?
Almost certainly
Avatar for Pred
Thank you. The answer either speakers indicates that I got Genuine Gen2 built
Hi, just received my sky glass, the model is lt155-01-sky-blk, can you tell me if it's the gen 2, it's volcanic grey so the speaker is the same as the TV, do they use blk even if it's grey? When I look at it it does look grey 😂 just want to make sure they sent right one.
@Anonymous
So my volcanic grey LT15501-blk is the gen 2, just confused me with the blk. Thanks for that.
Just found this....
  • Sky Glass TV build version: QS036.016.00P
  • Sky Glass Gen 2 TV build version: QS036.017.00P
That confirms it as well, mines on the latter.  Thanks for the help.
