Discussion topic: Continued loss of signal to TV
This message was authored by: KDJS
My TV is losing signal increasingly frequently. 3 times today already!
turning everything off and on again gets it back up and running but shouldn't have to do that multiple times a day.
any ideas / suggestions?
Re: Continued loss of signal to TV
@KDJS If you're using WiFi to connect I would suggest using an ethernet cable instead. It gives a far more stable connection.
If you are using ethernet already, make sure you have turned WiFi off in the Settings.
If your router is too far away then buying a pair of Powerline adapters would be a good investment (plus two ethernet cables).
This message was authored by: Jporch316
And if you are using Ethernet try WiFi  or a different Ethernet cable
Avatar for KDJS
Moved from WiFi to Ethernet.
problem persists.
how can I escalate to Sky? Pretty sure there is a fault with the TV
This message was authored by: Dazzasky
problem persists.
@KDJS I have escalated your post to Sky.  Keep an eye out for a message from them.
This message was authored by: Greenfingers001
Thanks for escalating this. We’ve sent KDJS an invite to chat.
Please be aware conversations automatically close if there is no response within 48 hours.
Avatar for KDJS
I may have missed something but am still awaiting contact
@KDJS
I have escalated your post again
please lookout for an invitation on this forum to chat with sky support team
This message was authored by: Lisa-P1987
Lisa - Sky Tech Team Expert
Avatar for KDJS
Lisa, again, sorry if I've missed something but I have had no action on this.
I'm still having to reset everything regularly and it's extremely inconvenient.
I would appreciate some help.
It seems clear that there is a fault that I need Sky to help with.
@KDJS what was the outcome of your private chat with the messaging team?
Avatar for KDJS
I've had no private chat I'm afraid.
My morning welcome to Sky ....again is an expensive Sky Glass  TV that doesn't work!
@KDJS  You need to ensure you lookout for a chat invite, if you don't connecte within 48 hours the invite is removed, an invite was sent on 29/06/2025 and again on 02/07/2025 are you logging in to the community every day?
We can raise another request but if you don't check at least 2 or 3 times a day and do it before the 48 houts elapse the invite will be closed.
Best to give Sky a call, then, as it seems their private messsging service doesn't work for you.
