2
This discussion topic has been answered Discussion topic: Changed broadband provider and sky glass tv won't connect to new network
This message was authored by: Kev65
I have just changed broadband provider but my sky glass tv is not picking up the new router.
This message was authored by: mikealanr Answer
Re: Changed broadband provider and sky glass tv won't connect to new network
Hi @Kev65
Try resetting your network connection as described here:
https://www.sky.com/help/articles/sky-glass-no-internet-connection-osm
Select Network settings on your TV.
Select Reset.
But I would then power you TV off at the mains for 2 minutes, switch the unit back on and go to network settings and try connecting to the router.
MikeAlanR
Hi @Kev65
Select Reset.
MikeAlanR
Avatar for Kev65
Hi Mike
Thank you, I have done all that and I've managed to pick up the new network now.
It wasn't letting me select a new network before, all sorted now, thanks for your help!
Kev
