3
This discussion topic has been answered Discussion topic: Cancelling sky subscriptions with Sky Glass TV
This message was authored by: Ol97
I have a sky glass tv, if i was to cancel sky ultimate, sports etc would the tv just work as normal?
This message was authored by: SKY1992bf Answer
Re: Cancelling sky subscriptions with Sky Glass TV
@Ol97  The link below explains what you do/dont get without a subscription
https://www.sky.com/help/articles/sky-glass-without-a-subscription
Hi @Ol97
@SKY1992bf has posted the information from Sky. While the article says "will work like a normal TV" it's important to note you will loose the TV guide function and can only watch live streams via the relevant apps (e.g iPlayer) unless you disconnect the TV from the internet and then you can use the aerial function for some DTT (Freeview) channels.
It might be easier to purchase a Freeview or Freesat box and and connect this, rather than dive in to settings to disconnect and reconnect from the internet all the time.
MikeAlanR
Normal TVs don't need to deactivate their network connection to access DTT🤔
