Discussion topic: Bluetooth speakers will no longer connect to sky glass.
This message was authored by: PaulGibbs81
I had successfully using my in ceiling speakers with my sky glass tv for a few weeks without any issues. The other day they stopped working with the tv and now every time I try to connect they it say can not connect. I had tried restarting both. I have tried forgetting the device and now it won't connect to them at all. I am at a lost what to do.  The speakers will connect with no issues to any other device but sky glass will no longer connect to any Bluetooth device. Anyone have any ideas?
This message was authored by: Greenfingers001
Re: Bluetooth speakers will no longer connect to sky glass.
This message was authored by: Dralliw
I have experienced a similar issue, there might be a glitch or bug in the software updates.
This message was authored by: Mazz1
Try having this issue with Hearing Aids! Thanks Sky thanks!
This message was authored by: Tommy7887
Good evening,
I am having the same issue with my Bluetooth speaker, it worked for months but now won't connect. Did you get this resolved, if so was it an easy fix?
