Discussion topic: Best way to contact Sky about their products
This message was authored by: Aakhan1
I have sky products ( sky glass, Telephone and broadband. It is extremely difficult to contact Sky.  Most of the precious time has been taken by the " virtual assistant" without any productive answer. This is really annoying.
Adding a product or upgrade is so easy and removing a product or to discuss with ongoing technical problem has been so difficult.
This message was authored by: Jporch316
Re: Best way to contact Sky about their products
Hi
try calling them and when prompted for your mobile number for text help just ignore and you will be transferred to a telephone agent
The best way to speak to Sky is to phone them.
The online virtual bot main use is only to redirect you to relevant documentation or guides from Skys website for issues that can be self resolved.
You can call on 150 from a Sky Talk Line or Sky Mobile.
https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number. If you are in the ROI on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
