Discussion topic: Best internet speed for sky glass
This message was authored by: Peter17
What is best speed for sky glass?   You can have 300 or 900 mps does this make much difference to the picture?
Re: Best internet speed for sky glass
@Peter17  You need a minimum of 25mbps for HD & 35mbps for UHD, however speed isn't the only factor, strong reliable wifi is needed or using ethernet, for stability is more important.
It's irrelevant if you have 500mbps to the hub if the TV is getting poor wifi from it.
Speed above what's necessary makes no difference at all to picture quality.
Avatar for Peter17
Level 2 icon
Thanks for your quick reply I was just wondering if super internet speed made much difference to sky glass
Avatar for Peter17
Level 2 icon
Thanks for quick reply
This message was authored by: Jporch316
personally (in my opinion) get at least 100mb if you have a plethora of other devices / IoT in your home. The faster the better ..........
