4
Discussion topic: sky glass remote battery life
This message was authored by selbymariner This message was authored by: selbymariner
I purchased sky glass and whole home with a sky puck for my bedroom. From the beginning the bedroom remote began to give the message that the batteries required changing. This happens several times a month and sometimes within days. A year or so later I purchased a new puck for a different room and this has worked successfully for almist 6 months now. However, in that time the original puck remote has had battery changes at least 6 or 7 times. The latest occassion I changed the batteries and immediately received a message to change the batteries. I didn't do so but now when I use iut I have to take them out and replace them again for it to work.
This message was authored by Jporch316 This message was authored by: Jporch316 Answer
Re: sky glass remote battery life
@Cyclops2
I have 5 remotes for 2 years and have changed then batteries in 3 of them once
The below may help.
The remote can be reset and paired again following these steps;
  1.   Press and hold 7 and 9 together on your Sky remote for three seconds.
  2.   Press and hold 4 and 6 together for three seconds.
  3.   Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
If not you can request a replacement remote under warranty via the following link
Replace remote
https://www.sky.com/help/forms/streaming-tv-remote
43inch and 55 inch Sky Glass & sky live camera 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims.
This message was authored by Jones_The_Cat This message was authored by: Jones_The_Cat
@selbymariner
The remotes are a bit of a car crash I'm afraid - mass manufactured and poorly made. There are constant reports on a daily basis on these forums of issues with them. I went through 3 in less than a year, two of them just stopped working for no reason. One thing I did find however was that the low battery warning was often a complete fallacy. One of my remotes carried on working for about 5 months after the warning started appearing.
All you can really do is request a free replacement remote using this form and hope you get a better one:
This message was authored by Cyclops2 This message was authored by: Cyclops2
We have 65" downstairs and a puck upstairs. The remotes eat up the batteries within 2 weeks no matter if they are expensive or pound land ones. It seems to be a problem with the remotes
@Cyclops2
The below may help.
Replace remote
This message was authored by Fothergill1 This message was authored by: Fothergill1
@Cyclops2 This is probably a fault with your specific remote. About a year ago I replaced a remote as the batteries were only lasting for 3 weeks.  At the time there were other people saying theirs were only lasting a matter of days.  My new remote lasted for about 10 months before the batteries needed replacing.
If the advice given by @Jporch316  doesn't resolve the battery issue you can order a replacement remote using the online form at: Streaming TV replacement remote
If my post has solved your issue please mark as an "Answer"
