2
This discussion topic has been answered Discussion topic: Wifi and Ethernet?
This message was authored by: BJ+Wilko
Wifi and Ethernet?
A simple question but want to make sure that i can connect 1 puck in main living room on ethernet and the 2nd puck in the bedroom on wifi? Can i just turn wifi off on main puck and the other in bedroom will work fine using wifi?
This message was authored by: Nigelb1972 Answer
Re: Wifi and Ethernet?
Yup. That's how ours are connected. Main one is via Ethernet with WiFi turned off and t'other is via WiFi. They work independently of each other so it's all good 👌
Yes. Each device is independent so can be connected differently
