Discussion topic: Wall mounting my sky glass
Message posted on 14 Oct 2024 12:23 PM
Does anyone know if its possable to wall mount a 65" sky glass tv on the wall using a tilt wall bracket?
Message posted on 14 Oct 2024 12:35 PM - last edited: 14 Oct 2024 12:37 PM
Re: Wall mounting my sky glass
Hi @Rhian8
You call wall mount using the supplied stand (it doubles as a wall mount). See: https://www.sky.com/help/articles/sky-glass-wall-mounting-guide
Glass also supports any VESA mount. However you need to make sure that the wall and wall mount can handle the weight as they are heavier than normal TVs.
MikeAlanR
Message posted on 14 Oct 2024 12:51 PM
And note that the wall itself is the most likely point of failure, because a tilted screen acts as a lever on the mounting bolts.
