Discussion topic: Wall mounted
This message was authored by: Nattallie
Message posted on 05 Jul 2025 11:28 AM
Wall mounted
Hi how do I get my skye tv mounted on a wall there does not seem to be any brackets that came with it
Message posted on 05 Jul 2025 11:48 AM
Re: Wall mounted
@Nattallie You needed to order the bracket at the same time as the TV, however VESA wall mounts are compatible with Glass. Just make sure they can take the weight of the unit.
Find out more
Message posted on 05 Jul 2025 04:10 PM
Re: Wall mounted
The Gen 1 (2021) model had a wall plate included buth the Gen 2 (2025) does not.
