1
This discussion topic has been answered Discussion topic: Wall mount
This message was authored by: Onnit
Wall mount
Can I have sky to supply and fit the wall mount and add it to the Bill please
This message was authored by: Anonymous Answer
Re: Wall mount
@Onnit Not if you don't order it at the same time as Sky Glass. Even then you will have to pay the delivery partner to wall fit it. It can't be added onto your bill.
VESA wall mounts are compatible - just make sure it can handle the weight and you'll have to sort out your own wall mounter!
Re: Wall mount
