Discussion topic: Wall bracket
Message posted on 01 Mar 2025 10:10 PM
Wall bracket
Our wall bracket was broken when we received our sky glass tv. Is there anywhere I can buy a new one? Don't think a standard bracket would work as the glass TV's are so heavy.
Message posted on 01 Mar 2025 10:22 PM
Re: Wall bracket
Hi @Atkins84
Was this a gen 2 Sky glass? If so as you have paid for it, it should be covered by warranty. I would call Sky and obtain a replacement.
But for Gen 1 & 2 they are VESA compliant so any VESA mount will work with them, but as you indicate you have to make sure they are rated for the weight.
MikeAlanR
55" Gen 2 Sky Glass atlantic blue, 65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Sky SoundBox. Former Sky Q, Sky+ HD and Sky+ customer.
Message posted on 01 Mar 2025 10:26 PM
Re: Wall bracket
I have no idea which one it is. It won't tell me on my app for some reason lol. It wasn't one of the new ones. I think I've had it for maybe a year or so.
Message posted on 01 Mar 2025 11:09 PM
Re: Wall bracket
Hi @Atkins84
It's a gen 1 then as gen 2 was only released a few weeks ago. Standard VESA mount will work as per above.
MikeAlanR
Message posted on 02 Mar 2025 10:36 AM
Re: Wall bracket
Difficult to understand how the Gen 1 wall bracket can be 'broken' : it's a single stamped metal plate which is also a fundamental component of the tabletop stand.
Message posted on 02 Mar 2025 01:09 PM
Re: Wall bracket
It had a crack going right through it.
Message posted on 02 Mar 2025 02:34 PM
Re: Wall bracket
I can only imagine that's an extreme manufacturing defect, in which case Sky should be prepared to replace it.
