4
This discussion topic has been answered Discussion topic: Untypical tv mount placement
This message was authored by: Kevin1311
Hello all!
odd question that possibly isnt common and and probably good reason for that but I want to mount my M Sky Glass over a serving hatch between two rooms, the size of the tv is not the problem but rather where the mount sits, the OE bracket wants to be placed directly in the hole, apparently 'sky hooks' aren't a thing so I was wondering if there's any wall brackets that would allow the tv to be offset much lower so I can mount the bracket above the serving hatch hole and still achieve the desired height, I doubt I have explained it clearly a diagram would've been better. thanks in advance
Re: Untypical tv mount placement
@Kevin1311
I doubt there's anything designed for that.
Options might be ceiling mount (ugly and somewhat fragile), floor mount (not particularly attractive) or suspension from a wall plate (could be tricky to keep parallel)
@Kevin1311
Avatar for Kevin1311
 here's a diagram I drew on a napkin ! Thanks again
Yes those were my suspicions, I guess building a wooden frame around the hole in the wall and wood screwing into that could be an option
